Class A Chimney pipe adapter
oldfarmall
9
Wisconsin
Hello-
Can anyone tell me if a product is made to adapt flexible stainless steel chimney liner to class A chimney pipe? Want to install a flexible liner in my 17" x 17" masonry chimney through the attic, then transition to Class A through the peak of the roof. The 8" x 8" clay liner will be removed first, as it is shot. I see Duravent makes a rigid liner (Duraliner) to class A pipe adapter, but can't find much about flexible liners to Class A pipe? Thanks in advance!
-Jesse
Hello-
Can anyone tell me if a product is made to adapt flexible stainless steel chimney liner to class A chimney pipe? Want to install a flexible liner in my 17" x 17" masonry chimney through the attic, then transition to Class A trough the peak of the roof. The 8" x 8" clay liner will be removed first, as it is shot. I see Duravent makes a rigid liner (Duraliner) to class A pipe adapter, but can't find much about flexible liners to Class A pipe? Thanks in advance!
-Jesse
yep, this is an example of what you're looking for but just from a different company: https://www.rockfordchimneysupply.com/products/rock-vent-transition-plate
Thanks Neverstop for the reply. Do any other manufacturers that you know of make a transition plate that works with DuraFlex stainless flexible 6" liner kit made by Duravent? I have access to Duravent products. I see Rockford chimney has their own brand of class A chimney.
I had a hard time finding anything else, which is partly why I went with rockford.
Give the DuraVent tech support line a call to see if they have a good solution.
