I have an existing masonry chimney, but want to install a new class A chimney pipe. The new pipe will be about 2 feet away from the existing masonry chimney. This is because instead of having to go into the masonry chimney through a thimble by way of a right angle coming up off the stove, the new pipe will just go straight up from the stove, and through the roof. My reason for installing the new class A, is because the existing chimney is not lined, and a new pipe will be easier to clean with being able to go straight up, instead of through the thimble. I also don't know if a liner will fit down the existing chimney.
I understand the 3-2-10 rule, as it relates to the roof ridge line. How about the existing chimney though? Does the new chimney need to be 2 feet taller than the existing one? Further, the existing masonry chimney actually has 2 flues, as there's another woodstove in the basement. Although I don't use it now, I might want to in the future as backup. Could I still use the masonry chimney, or would I need to discontinue it completely? Obviously both chimney's can't be 2 feet taller than the other, so how would this work if I wanted to use both (if possible)?
To complicate matters, it's a 12/12 roof, and the ridge line is 10ft away. Which means the class A height is a minimum of 12 feet. It's hard to find info about the maximum height of class A chimney from the manufactures. Would that height be an issue? Thanks for any help.
