Is chipped wood made from the small branches of a felled tree a desirable fuel in a gasifier? Ever used chips?
Mushroom Man said:Is chipped wood made from the small branches of a felled tree a desirable fuel in a gasifier? Ever used chips?
Briquetmaker said:I am trying to find out if I can burn 2" dia briquttes in a gasser. I installed a press at my shop to reduce waste and hopfully burn these. Not sure which boiler will burn these the best.
Briquetmaker said:does the size of the briquetts pose an issue of clogging the nozzle?
pybyr said:I've done paper grocery bags full of bark and bits of wood and it produces tremendous heat as long as there is a good glowing coal bed first.
I tried some things called "Ecologs" and was unimpressed with them- they didn't seem to coal and did not seem to generate a high temperature burn.
