I'm getting pretty fed up with installers who don't know anything about the new EPA stoves, take 3 weeks and 2 follow ups from me to send a quote, refuse to install dampers, etc. I'm leaning toward installing myself. Only connection I'm not sure about is this chimney thimble. These photos are of my oil boiler exhaust currently connected. Oil will be removed, chimney cleaned, and I will need to connect my double wall stove pipe here. This appears to be an 8" tile thimble? It seems about a 7.5" ID. That oil boiler pipe is 6" single wall. It appears my oil company has simply jammed rockwool to fill the gap and then hit it with some cement. Is this the correct way to attach my double wall when I install the stove? Or is there some type of adaptor needed?
![Chimney thimble connection Chimney thimble connection](https://www.hearth.com/talk/data/attachments/269/269397-c0058c8674d03235fdfc3a38d0ea9926.jpg)
![Chimney thimble connection Chimney thimble connection](https://www.hearth.com/talk/data/attachments/269/269395-4cb60abd1e360ad7368612b59a108e27.jpg)
![Chimney thimble connection Chimney thimble connection](https://www.hearth.com/talk/data/attachments/269/269396-1be0287019cf865d167dba81389a3847.jpg)
