This question is about the thimble clearance to combustibles. I Put a 6 inch insulated ss chimney liner in that stubs out through existing terracotta spout. The stud on the left is closer then 12 inches I was thinking of doing something with steel stud there then putting brick around like it showed in the manual. For an jotul oslo v3 f500. In that manual it says contact your dealer or local inspector for other methods. I didn't know if anyone had some info on this subject or if there was some kind of insulated thimble that would work better for this application. I attached the manual that information is one page 6. Also an opinions on if outside air vent should be installed. Any info would be greatly appreciated thanks.
![Chimney Thimble Clerance Chimney Thimble Clerance](https://www.hearth.com/talk/data/attachments/269/269094-0a9ff9dc4b8f266e37cdac0eed5876f7.jpg)
![Chimney Thimble Clerance Chimney Thimble Clerance](https://www.hearth.com/talk/data/attachments/269/269091-556ce7a2b5be7915553a1c4e7a28f37d.jpg)
![Chimney Thimble Clerance Chimney Thimble Clerance](https://www.hearth.com/talk/data/attachments/269/269092-6ff0ec4ff74e8d9d5d96bcdac01a9abf.jpg)
![Chimney Thimble Clerance Chimney Thimble Clerance](https://www.hearth.com/talk/data/attachments/269/269093-4cc9789246126abfe3f2ac41cb85c8f8.jpg)
