I have a add on wood and coal furnace.
I took the pipe off yesterday to clean and it was difficult getting a good draw until the fire was going last winter and got a lot of back or down flow from the masonary chimney.
The stove/furnace had very little soot in the pipes or the stove - less than 1/4 built up on the inside of the pipes/stove/chimney.
When I put the pipe back together am still having trouble lining up one section - yes it is the correct order as I took pictures and marked the sections before taking apart.
I have basically three questions.
1. DoI need to tape the joints - they were not originally taped?
2. There are a couple of extra screw holes in the middle section; I"m assuming from the original installation. Do I need to cover these holes?
3. Amy thoughts on the drawing/back flow from a cold chimney? Or how to get the stove/furnace to draw better from the start?
Thanks.
Thanks.
