Chimney Support brace Positioning
Andrew V
27
Rochester NY
I did a brief search but didn’t find much. I will be installing a section of chimney and will be required to install the roof brace kit, problem is I can’t figure out the best positioning since the chimney goes up the side of the house. See picture. Will one leg go up towards the ridge and the other on the lower end?
  • Chimney Support brace Positioning
I would think any direction you can get a good footing on the roof as long as the spread of the braces are approximately 60 degrees. You’ll definitely have a long and short leg though.
Reactions: Andrew V
Got it all installed. Bad part is I don’t think I hit a truss. I measured out what I though the standard was for truss spacing and I think I missed both times. Didn’t want to put multiple holes in the roof so I let it be. I sealed under the brackets so everything is water tight. I’ll re evaluate in the spring. The whole thing feels really sturdy so I’m not overly concerned for the winter
Reactions: Bigger_Al
You can get a longer thin bit and from the under side next to a truss and drill a hole from the attic. Then either push a long screw driver or coat hanger up the hole. Once on the roof you’ll know where the truss is and you can caulk the hole under the shingle and on top to seal it shut. Looking good though. :)
