Greetings,
I have a bit of a situation. I have some Hart & Cooley Stainless 8 inch (ID) chimney pipe that I would like to use for an install. The unfortunate thing is the piece of pipe that I have for passing through the Thimble is only 9 inches long.
I have been trying to source and 18 inch piece but have had no luck so far.
So here is my idea...
What if the Triple wall pipe outlet is recessed in the wall but yet meets clearance requirements? Please see my attached drawing.
Hopefully my drawing makes sense. I would essentially have the 8 inch triple wall pipe extend 3 inches into the recessed but open ended ( on the inside wall of house) box. The box might be 24 inches square. I would then come out of the triple wall with 8 inch double wall black pipe and give it 8+ inches of clearance.
What do you think would this seems like a plausible solution to present to the inspector?
Best Regards,
Coalholio
![Chimney section too short for wall... how about this idea? Chimney section too short for wall... how about this idea?](https://www.hearth.com/talk/data/attachments/232/232198-a033cce391744049bf0111fd7d6be27d.jpg)
Best Regards,
Coalholio
