Hello all,
This is my first post here, so I'll do my best to explain. My offer was accepted on a house in the Los Angeles area and all inspections went well except for the brick chimney. The major problem in the report is this:
"Displaced bricks and easy movement below roofline at bond beam located just below roofline" see picture, it was taken by the inspector. To show me the issue, he gently pushed the chimney while standing on the roof and I could see it move a bit.
Here's the quote I got from the inspector's company:
-Rebuild chimney according to city specifications for damaged chimneys, leaving original firebox and
installing UL Listed Class A flue pipe. City inspectors signing off on every required phase of construction.
-Remove chimney down to the top of the smoke chamber
-Supply scaffolding and roof protection if needed
-Protect interior and exterior areas as needed
-Form bond beam and special order transition with anchor plate
-Use Class A HT flue pipe system per city requirements
-Steel stud framing 18 ga.
-Strap all pipe per code
-Lath and stucco exterior chimney chase -from new construction up to termination. Scratch, brown and
color. No guarantee on an exact match of texture and color.
-Galvanized metal chase cover and manufacturers termination cap/arrester
-Fire stop assembly where needed- install fire stops / draft stops at required levels as per code
-Brace (single or double) if city request it
-Parge coat smoke chamber with hi-temp material
-Chimney roof tie in directly around the chimney. "L" metal flashing.
Price: $19,723.00
Is this accurate? I'm getting more quotes today, but this seems super high to me and I'd love some feedback if possible. I also am trying to get credits from seller regardless. Thanks!
![Chimney repair quote is $20k, thoughts? Chimney repair quote is $20k, thoughts?](https://www.hearth.com/talk/data/attachments/248/248254-9bc9b9b9dbf6384614b0ce98191f6218.jpg)
Price: $19,723.00
