Chimney Rebuild
Shadowdoc526
2
Albany, NY
I recently purchased a 115 yo house that has 2 fireplaces. The previous owners decided to raise the roof for added floor space and dismantled the brick chimney to about 2 feet below the roofline in the attic.
I was wondering what my options might be. Can a cap be used on the terminal end and then extend a metal chimney through the roof or does the brick have to be totally rebuilt through the new roof?
The heating system uses a different exhaust chimney on the other side of the house.
Thanks in advance
Mike
  • Chimney Rebuild
You can use one of these on each masonry chimney. After that's installed,
continue through the roof, flashing & storm collar all the way to the cap,
with Class A Chimney Pipe. You will have to use standard framing techniques
to box in the roof opening if your pipe location hits a rafter.
If the roof is trussed instead of stick framed, you will have have an engineer
sign off on the framing details.
  • Chimney Rebuild
