Fellow wood burners,
I have been following this forum for several years and have gotten lots of information. I only recently joined and appreciate the info so far.
I am currently getting ready to install an older insert into one of my fireplaces, I know, I know many feel that only the new epa stoves should be used and I do have one, an Appalachian 52 bay in my basement fireplace, but personally I like the older models like I grew up with better. I feel they throw out more heat and are more user friendly. That being said I have the older unit ready to install into an old heatilator double wall metal firebox masonry fireplace and I am torn on liner size.
The opening on the heater is 6.5 x 6.5 square. I know the math says I need an 8" liner. I am not and will not under any circumstance cut my heatilator because it has worked well as a fireplace and who knows what the future holds. So I have a section of 6" ss flex left over from the Appalachian install roughly 4' long that I tested and it goes through damper with no problems barely even scrapes. What would be wrong with running thy 6" section from heater through the damper then connect to 8" and running the remaining 25' out of chimney (which is 13x18 clay lined? I plan to use a dura liner round flat stove connecter mounted to stove which will cover the existing square opening and allow me to connect to round liner.
Thanks in advance for the answers. I will attach a few pics. (broken image removed)(broken image removed)
