since harman has put my boiler on the "extended" delivery, i am unfortunantly having to do some things somewhat out of order. i am going to make sure i have everything prepped for the boiler, where as i would have preferred to make sure the boiler is going to make it into my basement. confidence is high, so i am going to proceed with blasting a hole through my 2' stone foundation. enough of that - here is my question.....what kind of pipe am i running through my foundation? i am using dura tech chimney on the exterior of the house. what ever i am putting through the wall will have to connect to my class a clean out tee. i am thinking i need to run class A through the wall, since some of it will be exposed past my foundation, before it connects to the tee. so, then on the inside i need some type of adapter to take it from class A to stove pipe, correct?
thanks
thanks
