I have an outdoor insulated stainless steel 6” chimney (not enclosed). The chimney is 20 years old and has developed some small rust holes through the outer stainless steel. My understanding was that stainless steel doesn’t rust unless it has been damaged, but this is definitely rust (I was able to push a small nail through several of the rust spots). I don’t feel safe using the wood burner with this chimney so I plan to replace it.
I need to check with my local building department, but I assume I could do this myself (then again, maybe you need to be licensed?). I’ve seen several manufacturers list Class A Stainless Insulated 2500 degree Chimneys. I believe this could be replaced for under $1000 if done myself (It’s currently a straight shot up using five 3’ sections). One thing I’m not sure of is how easily the old chimney will come apart. It appears that the sections are of the twist-lock type, but if there’s rust inside as well this might be more difficult than I think. Does anyone have recommendations regarding this?
Thanks,
Al
Thanks,
Al
