I am about to install a stove in a small well insulated cabin(12'wide by 16'long with 6'insulated walls) and decided on the jotul F602 CB. Now that I am making plans for the stovepipe and it is a case of the more I learn about this the less I am certain what to do.
My question is what would be the better place for chimney placement - the roof is a cathedral, starting at 8' on the lowside to 12' on the high side, spanning the building width of 12' - I was planning on putting the stove in the corner - on the lowside I would have 6' of interior double walland with clearances I would have 6' of insulated pipe from the roof. Otherwise - if I put the stove on the high side - I would have 10' of interior double wall and 3' of chimney from the roof peak.
Which is better?
I am considering both cost difference and draft.
I should also say that winters here can range from zero to arctic cold.
I've attached a sketch.
Thanks.
Which is better?
Thanks.
