Hello,
First time post been reading lots of valuable information here.
I recently had my chimney inspected and learned that my 1947 house has an unlined chimney, I learned this is not safe to use. The inspector gave me a cost to repair that was much higher than I was willing to pay. I started looking into a wood insert. (This site has been an invaluable source) and think I have decided on the Lopi Large Flush Wood insert.
I have a few questions,
The chimney is in the middle of the house and seems to have a good draft when I put an incense on the hearth right outside the firebox. I was thinking about going with a 15ft Premium Smooth Wall Chimney Liner or the Smooth Wall Flexible Flue Liner from Rockford chimney supply. Will these liners give me to much draft? Should I go for a corrugated one?
Also I was planning on insulating it with 1/2 inch of insulation. And talked with some installer who said it was not necessary. I don’t think I believe them as when I read NFPA 211 9.5.1.2 it says 1/2 in of insulation drops my clearances to combustion down to 6in, My assumption is the bricks in the current chimney would take up that space. But then I go to 7.2.2.3 and it says it’s up to the manufacturers instructions, which the manufacturer says is UL 1777 listed which is a testing specification and really doesn’t give me clearances, therefore I am back to my assumption of the bricks between the chimney giving me the correct clearances when insulated.
I feel like I am going too far down the code rabbit hole and would appreciate some insight.
Thanks
Thanks
