First off I would like to say hello to everyone as I am new to this forum.
Here is the situation.
I purchased a house with a wood stove installed in the basement. Growing up my parrents always had one in my house, and wanted to be able to use one in my now new house (I am 22, and this is my first house). I climbed on the roof to examine the chimney flue, and saw that someone had run stove pipe up the inside of the brick/ceramic flu. Instead of cleaning the liner I completely removed it (all 20 ft or so) (note: when I say stove pipe I am talking about the black 22ga pipe that is availible at home depot or lowes) I purchased new stove pipe, and screwed all of the seams. The pipe comes in 2 ft sections with a 6" diameter. I did not put any sealant on the seams as they are tapered, and i thought that it would be OK. So I have installed my new stove pipe, and all the nessary elbos to connect to my stove. (note: it is multi fuel stove. it can burn both wood and coal) I used the owners manual to make sure the placement of the stove was to spec. The first time that I ran a fire the pipe smoked a little, but I figured that that was probally some kind of "break in process", and not to worry. I burnt wood for the first 2-3 weeks of the cold season, and now am on coal (roughly ~1-2 weeks).
Here is the problem:
Tonight smoke started coming out of the inlet of the chimney. Between the ceramic flue, and the stove pipe that I ran to the top. I immeadetly killed the fire, and climbed on the roof to see what was going on. It seems that soot has clogged the screen that prevents birds/leaves from entering the chimney, and was forcing smoke back down the flu. I dont understand why it has clogged so soon. (note: the wire that was clogged has openings roughly .5" by .5") Is it because of the stove pipe? Is it because of the wood/coal? What am I doing wrong? Is it normal to have to clean a chimney every 3 weeks?
