cll said:Summit what brand does elmer sell ?
cll said:Wonder if his 6 inch pipe will fit my 6.5 X 6.5 tile liner ?
summit said:cll said:Summit what brand does elmer sell ?
It is at least 5x the thickness of conventional chimney liner. It unrolls flat with no extra bending to makie it run straight, and very heavy duty. once you get it going it guides itself down the chimney with little prodding. You need a Metal blade and saw to cut it, no way a pair of tin snips will cut this. It's harder to lug up the roof, but easier to work with, is actually more compact that a regular thin wall ss liner because it does not need the large corrugations to maintain rigidity. Slides down a 7x7 flue where most of the standard 316 liners hang up. Next time you see a dump truck, take a look at the exhuast pipe, where it comes out from the chassis and goes to the vertical stack. That heavy flex pipe you see is basically how elmer's makes their liner.
BrotherBart said:For what it is worth, nobody has reported any flex liner crapping out on them in the four years I have hung out here. One dealer I talk with on the side has been installing them for twelve years and hasn't had one fail yet. And his people sweep them with steel brushes.
