Chimney kit questions
melvinjo
6
Salem, Mo USA
I ordered an 8" chimney venting kit (see pic)
Of course there are no parts names that go with the diagram. I have called and looked online, where I ordered and no one can seem to breakdown what part name goes to the numbers on the diagram. I have listed the parts by name from the boxes I have. Some I can figure out on my own so I left those out.
Hopefully someone can ID what parts correspond to what number diagram. I have:
-Wall thimble
-Tee with cap
-Barometric draft control (type M) (Do I even use it?)
-Tee without cap
-Single wall slip connector
-Finishing collar
-Adjustable T support
[Hearth.com] Chimney kit questions
one of # 12 is slip connector and however many single wall pipes you need, #4 tee with cap, 7 8 9 10 wall thimble and collar , #6 adj support, #11 likely don't need but that is where the damper would be put with the tee sans cap. hope this helps some.
Are you sure you need an 8" (ID) flue?
Ah, I see a papa bear.
-Wall thimble
-Tee with cap
-Tee without cap
-Finishing collar
No you do not use a barometric damper
