Hello to everybody ! I want to install an ironcast kitchen wood stove 9.5 kw with 5 inch flue pipe in my home that it have a kitchen also. The best place to be fit as per houses place is almost to center of home.
The roof is wooden with tiles tringle shape.
Because i dont want to drill the top of the roof just for safety reasons (maybe wood burn because i will not notice it). I want to pass the pipes in the way i show in attachment.
Please let me know what if this option is viable if not which is the maximum horizontal lenght i can have in order to avoid gas in home ? The total pipe height must be 12.5 feet in order to be 2 feet above the roof (the outside side of chimney will be insulated if order to avoid cold air).
Notice if i increace flue dimension from 5 to 6 inch this may boost the chimney draw flaw or reduce it ? Also if i place a rotary chimney cowl in the top or chimney this will help to draw better or not ? I want to install secondary combustion to my stove i dont know if this affects this because this mill draw air all the time and 1. this keep the chimney cool and 2. you cant semi close the exchaust outpout in order secondary combustion to occur.
What are your thoughts?
Best regards
![chimney installation chimney installation](https://www.hearth.com/talk/data/attachments/298/298297-fe4fa2880a9e399416ebada4c6b91395.jpg)
Best regards
