Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
If you have a liner installed, then the cracks one usually looks for aren't a concern. The reason to reline is to repair the cracks in the clay liner tiles. If you are concerned about brick cracks, they wouldn't be visible from the inside if there are clay liners in place.
Here's the thing... I just had a company do a fp insert install along with a new stainless steel liner. They didn't insulate the liner, do an inspection of the chimney, or get a permit. From what I can determine, the liner does not need to be insulated unless there is damage to the chimney. If there is damage, it might create the possibility of drying out the wood framing of my house and/or possibly catching it on fire.
I've made calls and some proffessionals say insulation is required and some say it's not. I just want to make sure that I won't void my homeowners insurance if there's a fire. The best idea I have as of now is to get the chimney inspected (hopefully with the insert in place), get the permit, then have the town building inspector come out to take a look. Am I worrying too much about all of this?
You are correct - the chimney should have been cleaned, inspected, and whatever local rules are in place need to be followed, like permits and building inspector visits.
I don't think you are worrying to much. You aren't likely to burn your house down, but you will be less likely when you follow all the steps. Give the post a read and fire away with any questions. We are here to help.
