Hi lm new here ....hoping someone can point me in the right direction....wanting to put my VC encore in my basement....its a walk out basement ...The main level cantilevers over the basement by 24 inches ...so if l go through the basement wall l can not go straight up the wall ...l was thinking of mounting the tee on the cantilevered part and supporting it with brackets from underside .....this would mean l would need a 36 inch piece of pipe to attach to tee and pass through the wall ( 10inches thick ) ...now on the inside l would need a 24 inch of double wall black pipe horizontally then elbow and 4 feet vertical to stove top. Wanting to use dura vent piping ....will have a 15 foot stack on it ....question is this lenght permitted ? Will l still get draft ?
![Chimney horizontal run ? Chimney horizontal run ?](https://www.hearth.com/talk/data/attachments/299/299655-83636cc741e6e7d7e1d65214cec7b108.jpg)
