Well I started the wood stove about 1 1/2 ago. I had the doors open as the fire was building and then I noticed the jet running sound. The fire was going fine but from sitting by the stove you could hear what sounded like a jet sucking/roar from the stove pipe up further. It stopped after a few minutes and I am letting the stove burn out. I know have a bit of a burnt food oder in the house. I cannot quite explain the smell other than it just stinks. THe stink is coming from the upstairs fire place where it has a large concrete chamber around the fireplace to retain heat when it is going.
I have been having creosote problems with the stove chimney.
Since I could smell the stuff upstairs I went into the attic (up to where the chimney is against the house) and no smoke or smell there. Walls everywhere are cold to the touch. I am able to see on both sides of the chimeny concrete structure due to an access hatch on one side and an ash dump on the other side. I am at this time certain it was contained just in the tiles.
This is scary stuff. The chimney is completely an outside one and is completely concrete encased but still makes me nervous. Once the stove is out I will brush the chimney out later and see what if anything can be seen.
It is clear that this will not be used anymore until a liner is put in.
Sad thing about this is I just two days ago bought a Hearthstone Mansfield soapstone stove which is sitting in the back of my truck.
Short of the droaning sucking sound the stove worked normal as can be.
I just hope this is all that happens and can be thankfull that nothing burns down.
