So, we had what we suspect was a relatively minor chimney fire. Now I feel like I'm on high alert all the time and I'm kind of nervous whenever we have it running... which is always.
Here's the particulars:
After they took a look, they asked me all the questions that the particulars above are the answers to. I let it die down and pulled the black double wall section. There was some creosote flakes in the there and you could see where it had been burning in that upper elbow. Looking up through there was some larger deposits at the seams in the stainless sections but nothing major. At it's worst the build up was a couple mm deep. It was mostly loose flakes.
I had this stove growing up and I like to think I know how it should run. I like to get a good bed of coals and then back it off to burn slowly without smoldering. I've resigned myself to pulling the black pipe monthly to inspect it. I feel very gun shy about letting her rip and I'm wondering if any of this raises a red flag for some of you more experienced folks out there.
One last thing to note that I'm currently trying to remedy. The section of pipe that attaches to the stove is a little funky. The crimped/tapered end that was part of the telescoping section that should have fit inside the stove hole was just too big to fit. I found that I could pull apart the two section of that telescoping piece and it fit snuggly, if not perfectly airtight around the outside of the pipe. There's no noticeable air suction sounds coming from there that would leave me to believe that air id being introduced to the flue at this spot. Regardless, I'm going to try and get the guys at the stove shop to get me set up with an appropriate adapter with the crimp/taper I think it needs.
Hit me with your thoughts,
Freaked in Maine
![Chimney Fire Jitters Chimney Fire Jitters](https://www.hearth.com/talk/data/attachments/170/170331-03f5d38f40ee5df3104ec7127f28f674.jpg)
- New insulated stainless chimney installed up through the middle of the house. Installed mid October and used almost daily since
- External Chimney is at peak and extends a good 3'
- Pre Cat VC Intrepid in good shape. Airtight except for a tiny speck of light at the top of the gap in two front doors when closed
- Double walled black pipe with two 45 degree elbows (picture)
- Kiln dried hardwoods
- Use some pine scrapes when starting
Freaked in Maine
