Hi all! I am buying a home with two wood burning stoves. The usual pre-purchase home inspection was performed yesterday afternoon. My home inspector called out the large Franklin stove, citing clearances and safety issues. He also noted the close proximity of the chimney to the evaporative cooler that is installed on the roof. He strongly recommended that I have out a local stove installer/service to further inspect and point out violations/remedies.
I will be doing that.
My question... what is the required clearance for the chimney in this situation where there is a mechanical appliance sitting right next to it that draws outside air into the home? I am having trouble finding that info for this scenario, and if a chimney and an evap cooler are even allowed to exist in close proximity, as is seen in this case. We want to remove and replace the old Franklin stove with a new efficient model, but I am now wondering if any stove will be allowed to have a chimney penetrating the roof in this spot that is going to be this close to the evaporations cooler. Appreciate any info/insight.
Here are some pics of the roof from above showing the issue, and a pic of the stove inside the house... you can see the vents that blow in air from the evap cooler.
![Chimney clearance from nearby evaporative cooler on roof Chimney clearance from nearby evaporative cooler on roof](https://www.hearth.com/talk/data/attachments/308/308914-9e7649df09b6248217ac295f16acc3a2.jpg)
![Chimney clearance from nearby evaporative cooler on roof Chimney clearance from nearby evaporative cooler on roof](https://www.hearth.com/talk/data/attachments/308/308915-7fc376aef5ed7208a3e1c05d5cf87726.jpg)
![Chimney clearance from nearby evaporative cooler on roof Chimney clearance from nearby evaporative cooler on roof](https://www.hearth.com/talk/data/attachments/308/308916-03e6a49c79d0f7ecc4f309489b8a68ff.jpg)
