Hello everyone,
I did a chimney cleaning on our Pacific Energy FP30 for first time after 3 years of used. We used the unit only in weekends so I said is time to do it. Overall a straight forward process; the challenge was to go and stay safety on the 6/12 metallic roof. Unfortunately I wasn't able to disconnect the chimney cap so I was forced to disconnect the last 3ft chimney piece in order to drop down the brush. Pushing down the brush was little bit tricky; the brush has metallic wires and looks like is a little bit oversize for my 6" chimney but I assume it's designed for a snug fit. Our chimney is 19ft tall so at the end of the push it got stack; I wasn't able to push down or either pull up; lucky, the brush was at 1-2 ft from inside the unit so I was able to pulled down from inside.
I attached a picture with the creosote collected and I believe is faire amount but surprise to see a lot on the cap screening as can be seen in picture.
The question for whoever knows, is about the gasket which looks like need to exist between baffle and the air tube. I couldn't find in mine unit during the cleaning or it burned during these years or I damaged when I removed the baffle? I assume it needs to be there, correct? Will be the unit efficiency affected without? What is the role of it, sealing the fresh air to the baffle?
Another question is how well those chimney pieces are sealed together? Removing the last piece from our chimney, I was surprise how the creosote extended on entire area between the parts, so I have a concern about connection points which are in the attic. Will some smoke can escape? I double check but I couldn't see any discoloration on the chimney located in the attic. Any comment on that?
Cheers.
![Chimney cleaning for a Pacific Energy FP30 and 2 questions. Chimney cleaning for a Pacific Energy FP30 and 2 questions.](https://www.hearth.com/talk/data/attachments/282/282743-4822a7e8a1760106b9e49f2697271e4b.jpg)
Cheers.
![Chimney cleaning for a Pacific Energy FP30 and 2 questions. Chimney cleaning for a Pacific Energy FP30 and 2 questions.](https://www.hearth.com/talk/data/attachments/282/282740-dd4539b55847d403549ee7771ec31f42.jpg)
![Chimney cleaning for a Pacific Energy FP30 and 2 questions. Chimney cleaning for a Pacific Energy FP30 and 2 questions.](https://www.hearth.com/talk/data/attachments/282/282741-3edea82baa48c3245c7c0337e94bdb5c.jpg)
![Chimney cleaning for a Pacific Energy FP30 and 2 questions. Chimney cleaning for a Pacific Energy FP30 and 2 questions.](https://www.hearth.com/talk/data/attachments/282/282742-4f7177c46ecacae0248ea64a81a120df.jpg)
