Chimney Brush - 5 In or 6 In
joesat78
55
Central PA
Forumers,
My 6inch SS liner was slightly ovalized to fit into the masonry chimney. The installer suggested to use a 5 inch brush while cleaning. I was thinking would it be a good idea to buy a 6 inch brush and trim 1/2 inch on either side to ovalize the brush instead of a 5 inch brush?
Thanks, Joe
It might depend upon how "slightly ovalized" the pipe is. You may not even have to do any trimming! If you can buy the brush locally, then perhaps you can get one of each and take back the one that won't work out for you.
If you stay away from the wire brush, you might be okay with 6" because the poly are quite flexible.
The stiff bristles act as ratchet dogs. They will bend enough to go in but will take some effort to pull it back out. The trick is to put a little spin on it while reversing. Just make sure you turn it in the right direction so as not to undo the joints of the rods.
I don't think making the brush oval will work well as I doubt you could index it. Buy the 6 inch and try it. You can always trim it all the way around.
Brushes are available in all shapes and sizes...including oval. Just depends on what you mean when you say "slightly". Rick
joesat78 said:
Forumers,
Thanks, Joe
Had the same hurdle. Read this thread..
https://www.hearth.com/talk/threads/26704/
