I didn't see where anyone said it is not a legal installation - I have seen many oil furnances and fireplace chimneys located in garages while the appliance was inside the basement or living room.
Elk, did I miss something....or did you just jump on the dude before you explained why a class A chimney (with firestops) cannot penetrate a basement wall.
Please explain - I have seen dozens of chimneys located in garages....has that not become verboten?
From my experience, there would be no problem locating a chimney in a garage - I have done it many times (permitted), for instance when a prefab was installed in the living room and bumped out. We did always have to box in the chimney so that things in the garage could not rest against it, etc.
From a common sense perspective, can someone explain to me how fire is going to jump from the garage (for instance) back through a hole in the foundation which is firestopped? Or, how it can jump from the basement through the hole the other way into the garage? maybe I am missing something?
Copper, since you cannot get in touch with the local officials, let me suggest two things:
1. Have a certified installer look at it...or at least see the plan
(broken link removed to http://www.nficertified.org/pages_consumers/consumers-4.html)
and
2. Call the tech dept of a major chimney maker (or PM "Metal" here.....) and ask if this seems right.
All of this info assumes your basement ceiling is at a higher level than your garage floor, so that you can get the pipe through the wall and be above the garage floor level. If not, all bets are off (you can't do it for sure).....
tech support for metalbestos, for instance:
Karen Marchand
Selkirk Corporation
State Route 93 N. & Sutton Road
Po Box 631
Logan, OH 43138
740.385.5666 Ext. 2212 - Voice
740.385.2483 - Fax
[email protected]
