hi everyone , i know that the flue size must match your stove size for proper draft ... and if to small it will draft poorly.... but ive read that if it is way oversized it will also draft poorly --- i thought that to big of a flue would cause out of control drafting , but the theory was that because the flue was to big that it would never quite reach a good drafting temp. ?? is this true ---- trying to decide on how to tackle my chimeny??? i have a wood furnace with a 6 in flue and my chimeny flue size is approx. 9x9 ?? its the old clay rectangular type . once i get a good hot fire going it seems that it drafts just well enough to keep the furnace running properly ( i actually have the best results when i leave the ash door open, but then have no control of the draft, ) the real problem is when the house reaches temp. and the stove begins to "idle" , the fire will really start to smother and smoke usally starts puffing out of any crack it can find( like an old wet campfire), so could this be the problem or is it some other complicated draft issue.. also if i do need to reline it what type of pipe is suitable ---- size and kind .... does it have to be the double wall stuff being that it is already lined with the clay ????? thanks for any help
