Well I am using the Vigilant tonight after not using it yesterday and while using it tonight for the first say 3 hours it has continouly dripped water out of a seem in the 90 deg elbow.
It is a clay tile 8X8 and my concern is there is a crack in it somewhere between the wall and the second 45 degree turn it takes going up to the roof.
I tomorrow will run my video camera in it somehow to see if it is possible to see anything but am doubtfull as to how this will work. I have in the past tried calling several chimney sweeps in our area and none of them seemed any more informed than I am about it. I even think in most cases I knew more about how the chimney behavior then they did. None of them had a camera for inspection.
The only place in my area that sells stoves said reline it and all problems will go away. This guy I visited yesterday and was also trying very hard to sell me a Lopi Leyden (which I must say I really liked but seems to possibly have some issues) $1780 with blower. I just am not 100 percent comfortable with these guys though. Kind of get the used car salesman feeling about them but they have been around for a while.
If I have the flue relined how does this happen? Does one have to knock out the tile with a drill with some type of hammer thing on it. To allow a drop in liner to fit that can make two 45 downward turns to the thimble? Can the liner be insulated. Can I do this myself with the help of a freind or two and if so how does one buy the liner and what type?
I am at my wits end with this problem. The stove has been running no lower than 500 since started and more at 600 than any other temp. Wood is not sizzling. Stove seems to be doing all that it should.
If I relined then that would also mean buying a new stove as the Vigilant is to be run on a 8"flue.
