First big chill down of this season, -19F forecast for tonight. High today 0F, which it is right now (9:05am). Got a jump on charging 1000 gallon storage yesterday afternoon, and topped it off this morning, which should last until Monday.
It is the end of burn. Notice stack temp of 132F; also radiant is "off." When the radiant circulator is "on," radiant supply is about 100F via a mixing valve which mixes down the tank temperature.Why is your supply 20* less than your boiler top temp?
No voodoo (well maybe a little). The Solo Plus 40 has an operating thermostat knob on the front panel which provides a small range of adjustment on output supply temp before the draft fan shuts down. The manual says the minimum is 180F and the maximum is 190F. I have found that when the boiler is operating and the boiler circulator is "on," such as when charging storage, the actual output supply temp is higher than the thermometer reading on the front panel. My circulator moves about 14gpm through the boiler, and I suspect the water flow route through the boiler quickly moves the hottest water out the supply and slightly cooler water remains at the top of the boiler where the operating thermostat sensor is located. Anyway, I can get actual supply output up to about 196-197F before the draft fan will shut down, and at this temp the thermometer reading on the front panel will be about 192-193F....did you have to modify your Tarm Solo Plus to allow you to heat your storage up to 195 degrees...
The reason I asked is because my garn Jr. In my shop temp. Is 194* after my burn and I have 72' of insulated line down over 48", going into the basement. The temp of my water there is only 150* and I can't figure out where the other 40* went?
I believe I have a 50 plate hx with a taco 007 circulating at the boiler and I'm pulling with a wilo pump in the basement. Everything seems to work fine.
The garn draws from about 4" or so from the top of the boiler and I put a thermometer in the top so I know that reading is accurate and I have two thermometers downstairs both reading 150*, help!
