Hey folks. Just figured I'd share my recent experience with a new-to-me brand of pellet I have started using. I've burned through my entire 4 ton stash of Heatr's and needed a few more bags to keep the basement warm for my downstairs tennat, so I picked up 16 bags of Cheat River pellets from my local Lowe's @ $5.75/bag out the door. 16 bags is definitely most my quarter ton Chevy (2003 Impala) will handle. Anyways, I cleaned out my hopper and did a deep clean on the whole stove so that I would have a good performance comparison against what I've learned about the Heatr's over the burning season.
First, on visual comparison the Cheat Rivers are darker, and on the average a good 1/4" shorter than the Heatr's. They definitely don't have the strong wood/pine smell that the Heatr's have. They also aren't sticky - they feed great where-as the Heatr's could run stop feeding the auger with more than a bag left in the hopper because they would just cling to the sides and let a big hole erode though the middle.
So, man they are HOT. I started the stove up and left it on full power, where I usually run it. I have a temp gauge mounted on the heat exchanger exhaust. Typically the Heatr's could push that up to 225-230*F after about 4hrs of running at full power. After running for 2 hours with the Cheat River pellets I was reading 270*F, and it probably would have kept climbing. It did appear to be running a little rich, so I backed down to heat level 5 (of 9) - the heat stayed right around 250*F at that setting. I believe that the smaller size does cause things to feed quicker, but I know at heat level 5 I'm definitely burning less pellets and seeing significantly more heat. The only downside is that they do seem to produce more ash, but I guess with more output that is not unreasonable. I'm definitely really happy with them. Where were they in February when we broke the 118 year old record average low temp!?
