Taking my recently moved out 19 y.o. son a snow shovel, (the one he used to use) to save a buck anywhere he can
just like the ol' man, drove past a window fan unit sticking out of a garbage can. Being an avid dumpster diver
I snatched it up on the way back and got to work. We've hadda box fan hanging in the stoveroom and one at the
opposite cold end blowing cold return air. Effective but ugly. One side ran great but stopped immediately when
shut off. The other side ran slow and was humming. No small wonder it was tossed. I knew it was fine but
never serviced. No one services a fan, except me. (They dont break down unless a blade actually breaks.)
!["Cheap" airflow project "Cheap" airflow project](https://www.hearth.com/talk/data/attachments/190/190334-1d91a6969c283df126eba0f90a56e594.jpg)
This thing belonged to smokers. Yellow, and full of crud. Hairs wound around the motor shafts, it was truly
garbage. Took the brush and some bleach water to remake it white again. From the pic, you can see the main
barrels were fine though. Cleaned up the motor bodies a bit and a dab of grease on a Q-tip shoved down
both lower caps completed the bottom end "rebuild". Measured and put a board where the box fan used to
hang ugly. Put the thing back together all shiny and white, tucked the wire to hide it, and there it is. Warm air
blowing down towards the bedrooms. The fan itself is not mounted so it can be turned towards the right of the Christmas
tree where mama's daycare room is. (dining room, table in kitchen) Price: Zero. Labor: Bored anyway.
Have a warm day, fellow stovers!
!["Cheap" airflow project "Cheap" airflow project](https://www.hearth.com/talk/data/attachments/190/190331-f74c71755d54ce8364d99a8dd632b832.jpg)
!["Cheap" airflow project "Cheap" airflow project](https://www.hearth.com/talk/data/attachments/190/190332-9700946568e8ce8bcba7ce7fdb42e37d.jpg)
!["Cheap" airflow project "Cheap" airflow project](https://www.hearth.com/talk/data/attachments/190/190333-365fc5a1f9ea15adad8c8f7bee94b2bb.jpg)
