I have an RSF Focus 320 Wood fireplace installed by the local dealer. A carpenter and myself built the chase structure ahead of time as per the specs of the manual and talking with the dealer several times.
The fireplace install team seemed to do a good job but when it was all done I did some checking and found the chase area gets quite hot. I asked their technicians about it but they didn't really know if that's typical because they usually close up the front wall with tile, brick, etc and head out to the next job. In my case I don't have the tile or mantle installed yet so I still have access to the top of the fireplace and the chase area so I took some temperature readings.
After running a few hours the chase walls get up to 188F sometimes and that worries me. I think I need to redesign the chase venting, add a fan, or adjust how it's insulated. The RSF Focus 320 is on the main floor with cathedral ceilings. I bought the internal blower option and the basement heat dump kit with blower.
The chase is part of the house thermal envelope and is air sealed and insulated with 2x6 construction. It's 2ft deep, 6ft wide and 25ft tall. The Chase extends 7ft above the roofline and is insulated the entire way up. The insulated SS pipe terminates 2ft above that. It's quite tall overall.
The stovepipe is the proper dual wall, ICC brand 7" ID 9" OD stainless steel insulated chimney. It goes straight up with no bends of any kind. It has the factory spec vented flashing at the top along with radiation shields and so forth where it passes next to (through) the roofline. I also have far more than the minimum clearances of 2" to the chimney. The chimney actually has 7" clearance to the back and front walls and 27" to the side walls. That's far more than needed but the problem is the whole chase gradually gets really hot over the course of a few hours.
The chase walls are 2x6 studs insulated with spray foam to R20. It was sprayed from the outside onto the back of the drywall between the studs. Then covered with OSB, housewrap and vinyl on the outside The inside is fully lined with 5/8" type X drywall. The top of the chase and the chase liner next to living rooms wall has 1/2" Durock cement board for safety rather than drywall. Now I wish I had used Durock board on all the interior surfaces because drywall with paper facing and wood framing isn't really meant to take 180 to 190F degree's long term.
I read the temp with a fluke IR meter and also installed a J-type thermocouple up near the top of the chase and they agree on the temperature. I also have thermocouples on the firebox, chimney flue and the outer chimney pipe.
Firebox top = 250-330F depending on burn rate
Flue pipe 4" above firebox 400-680F
Chimney outer wall temp = 150-190F
The lower chase where it shares room air (due to no inner wall yet) stays cooler at 115F.
The upper area's of the chase run much hotter and the ceiling gets up to 188F. I'm sure having the house walls insulated is not helping because other than the small vent at the top the heat has no where to go. This used to be an outside wall so it's insulated. So the upper chase area ends up being insulated on all 4 sides.
I'm considering removing the living room drywall above the fireplace to access and remove the original insulation so the excess chase heat can flow into the house rather than being trapped in the chase.
Or, I could add passive vents or thermostatically operated fans in the chase to send the heat back into the house, effectively cooling the chase. It's certainly hot enough so I'm not worried about cooling the chimney itself too much. I read 300F+ coming out the top of the chimney.
I'll try and post a picture to make things more clear.
Basically... is it ok to vent the chase heat back into the house? especially when it's far hotter than it needs to be?
Lastly, the fireplace installers did not install a firebreak of any kind because I have cathedral ceilings even though I think it still needs one. The chimney didn't pass through any floors even though the house has a 2nd floor a few feet over from the fireplace. So I installed a Durock board firebreak about 7ft above the fireplace (11ft above the floor). I left a 1 -2" air gap around the chimney. The durock board cuts down the room air that was blowing out the top of the chase and also I didn't like the idea of having no firebreak at all. RSF sells an air tight radiation shield for high efficiency houses so that implies I could seal off the firebreak completely to stop the air loss but I didn't do that till I find out more. With the chase open to the vent at the top I was getting frost on all tiny air leaks in doors and windows since the top vent in a tall, hot chase depressurized the house a lot.
Thanks for any insights on the best way to make this a safe install.
Note there are 4 JPG photo's attached, but the preview only displays the first one, so far.
Regards,
Dave
![Chase area around wood fireplace gets too hot Chase area around wood fireplace gets too hot](https://www.hearth.com/talk/data/attachments/120/120443-242d512b6b54247c4327d7c4d025c02d.jpg)
Regards,
Dave
