My new to me home was built in 1962. It has an LP boiler and a Char Lite wood burner hooked into the same system. Copper lines are embedded in the plaster of the ceiling of the main floor & in the concrete of the basement floor, so there are no registers. I'm doing my best to figure out the system and make it as efficient as possible in the future.
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193098-4c49518ded9af5b7c5f472857c384573.jpg)
I picked up a cheap thermal camera which has been worth it's weight in gold. I've been using it to bleed lines after I had to drain the system, locate pipes for remodeling, and just learn the system in general.
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193099-2163f0ab2a13bf882de76b89470e4d28.jpg)
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193100-c396d3f0dbcde3ba32affd6d91873dfb.jpg)
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193101-4f30580c93d003c4aae445d67967e63b.jpg)
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193102-559e08d06005b037d4834026a3c617b6.jpg)
I started burning wood but was not getting the results I hoped for. I believe my main problem is wet wood, but the first thing that helped was emptying out the ashes. The previous owner probably hadn't done that in years and I scooped about 15 gallons of ash out. I believe this was keeping some of the heat from the system.
I could use some advice on the next attempt. I noticed a box of fire bricks in the basement and the wood burner had a lining of them in the bottom. I removed them thinking they could be insulating from heat and they weren't meant to be there. There is a hole rotted through the metal floor so I can see the benefit of them eliminating that. Should I put fire bricks back in?
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193103-71c8022ff6f0ecbee02267ceb4dc15d1.jpg)
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193104-5427c0a336602e77b66ea62079dba4ac.jpg)
![Char-Lite wood burning boiler, ceiling radiant Char-Lite wood burning boiler, ceiling radiant](https://www.hearth.com/talk/data/attachments/193/193105-b6a4a6fa95a0040e6a0ba05757a55d7f.jpg)
