After reading a bunch of posts on Old fisher stove baffle plate
This is essentially what i used to have for a baffle
It worked ok. however smoke was still a serious part of the stove. And quite alot of the wood would burn up quickly. It took me about 40 minutes in the morning to get one liter of water boiled. Also i really had to gun the stove to get a hot fire. It heated well. Though it lost that heat just as quick.
I have since thanks to many threads on permies. Changed my baffle plate around and added a new one. See photo
Note not my stove.
I now have a better performing stove thanks to this simple addition. It heats up easier. it holds the heat for longer. It Smokes less. and as far as i can tell it uses less wood.
I have about three inches of clearance to the front door and three or so inches of clearance to the top of the stove.
This worked for about 1 day until i discovered i had many air leaks. The flame path was going about 4 different directions.
so i was not completely satisfied with the improvement. The old bricks i had cobbled together were slightly different heights. And they had more joints which meant more air gaps. The flame path was going every way.
I am not super stoked about these bricks. They are about 1000 grams lighter than the other brick i have
Than i decided to put myself in my firewood's position!
3 new bricks on each side and 3 smaller pieces for the back of the stove.
Now the flame path is pulling up to the front of the stove. Much better!
Top of stove with our hot water heater in the stove pipe.
I am soon to be getting a Infrared Gun!
So i will be able to get some temps on the stove.
To see the original post on Permies
Note not my stove.
![Changing the flame path on my fisher stove Changing the flame path on my fisher stove](/talk/proxy.php?image=https%3A%2F%2Fpermies.com%2Ft%2F137469%2Fa%2F129058%2Ffisher-stove.jpg&hash=263da5eeb0fb913e40e90deb1e145df2)
![Changing the flame path on my fisher stove Changing the flame path on my fisher stove](/talk/proxy.php?image=https%3A%2F%2Fs8580.pcdn.co%2Fwp-content%2Fuploads%2F2015%2F09%2FMilwaukee-2278-20-M12-Infrared-Temp-Gun-324x324.jpg&hash=9a678c1fe7b0725ddc42c668a9b5ee06)
![Changing the flame path on my fisher stove Changing the flame path on my fisher stove](/talk/proxy.php?image=https%3A%2F%2Fpermies.com%2FmooseImages%2Fbetaview%2Fpermaculture-gardener-edited.png&hash=b05dcbf17aa6af1957c1ccb5b962835f)
