Here's a question in hopes that someone may know, or have suggestions on where to look (initial Google searches did not yield any answers).
I wanted to measure the moisture content of some of my late-cut wood, but did not want to spend $ on a moisture meter, since most other than the really expensive ones seem to be poorly made. And they're really not that accurate, as the relation of electrical resistance to percentage moisture varies a lot by species.
So I looked up the US Forest Service table for converting megohms of electrical resistance to moisture content, by species.
Then I split open a piece of White Ash, drove two nails into the wood, 5/16 deep and 1.25 inches apart, in line with the grain, as is the standard for measurement.
Then I clipped the leads of my good-quality Beckman digital multimeter onto the nails.
Measurement started out up around 8.4 megohms, but the numbers on the digital readout kept changing, and in a decreasing direction.
15-20 minutes later, it seemed to have stabilized at about 2.8 megohms.
I'm just plain curious on what would be causing that change- and also what it means for the accuracy of "quick" moisture meter tests.
