Chainsaw
manada_hill
16
PA
Anyone has a Makita Chainsaw DCS520? I'm looking for a review for the DCS520 chainsaw in the web and couldn't find any?
thank you!
Same as Dolmar. I like Dolmar products. Good saws at a better price point. They don't seem to take wood porting as well but power is adequate for most people.
thank you!
I've got the newer model that replaced it. Makita DCS510. For a professional-grade saw this size range, it's one of the best I've owned in 50 years. The DCS520 is the older-generation Dolmar - pretty much the same as the Dolmar PS-540 with slightly less power. The new saw with a few less CCS weighs two pounds more so maybe they beefed it up a little.
I've seen the parts breakdowns and it looks as though they both have great build quality. The new model make a little more power with less CCs.
The Makita/Dolmar DCS520 - - bore - 1.73†(44 mm), stroke - 1.34†(34 mm). 2.4 KW power at 9000 RPM and torque is 2.9 Nm at 6000 RPM. Dry saw weights 10 lbs.
The Makita/Dolmar DCS510 - 1.77†(45 mm), stroke - 1.24†(31.7 mm).
Power 3.3 KW at 10,000 RPM, torque - 2.9 Nm at 7000 RPM. Dry saw weighs 12 lbs.
jdemaris said:
thank you!
I've got the newer model that replaced it. Makita DCS510. For a professional-grade saw this size range, it's one of the best I've owned in 50 years. .
Thats gotta mean somthing. :coolsmile:
The pro saw is the 5100 or newer model 5105. Pro models have mag cases and no load tach at 14,000rpm.
I got the 5100S saw... great saw... I like Dolmar/makita products...
