Anyone that takes there chains to the dealership to be sharpen what do they charge you, and what size chain?
Adirondackwoodburner said:come on, nobody should have to do that.
Adirondackwoodburner said:I guess I dont understand this. so you are using yoursaw for a few hours or say one or two tanks of gas and then it becomes dull so you take the chain to the shop to ahve it sharpened? That makes no sense. I sharpen my chain at every fillup minimum and work all day long.
Danno77 said:what am i doing wrong? At about two tanks of gas I don't notice any loss, at about three I might notice some diminished cutting, and usually around 4 I need to sharpen it. I've gone longer and certainly i've gone just a minute or two before I dulled it on rocks or nails or something.
lol, maybe my saw is running too rich and i'm just eating up the gas, so my fillups aren't the same as y'all.
It seems better to touch them up after each tank or 2 and have a really sharp chain all the time than to run them until dull. Just my $.02Danno77 said:what am i doing wrong? At about two tanks of gas I don't notice any loss, at about three I might notice some diminished cutting, and usually around 4 I need to sharpen it. I've gone longer and certainly i've gone just a minute or two before I dulled it on rocks or nails or something.
smokinjay said:Danno77 said:what am i doing wrong? At about two tanks of gas I don't notice any loss, at about three I might notice some diminished cutting, and usually around 4 I need to sharpen it. I've gone longer and certainly i've gone just a minute or two before I dulled it on rocks or nails or something.
if I run 2 tanks out on either or both saw's there is a lot of wood to be moved,but I also run with razor shape chains no matter what. Have a dozen chains ready to go at any given time just makes it a lot funnier with great chains (you never know when your going to hit something or rotten wood)
blades said:sharpening chain around here 6-7 bucks, most of them do not take the time to due them properly and never seem to touch the depth gauges. I charge 6, if they bring it in on the saw it is no biggie to me and I will clean up the bar also. the little extra on the bar seems bring in a little more down the road apiece.
smokinjay said:Anyone that takes there chains to the dealership to be sharpen what do they charge you, and what size chain?
Nixon said:Probably redundant, but make sure to check Your chains ranker height as well as just putting an edge on Your chain .
You can sharpen a chain "til the cows come home but, if the ranker height is wrong,it won't cut worth beans .
