bluedogz said:
So I'm getting ready to drop more money on a new chainsaw than I think I've spent on all previous chainsaws combined.
Folks here recommended using a "narrow kerf .043" chain; I've also seen references here to "skip tooth" chain and other references that make no sense to me.
Any resources to learn a bit more for a chainsaw rookie? Even Google isn't much help...
Skip tooth chain simply has every other cutter missing. It's for saws running super long (28" +) bars or saws running a bigger bar than it would normally. The idea is there are less chips in the cut to clog up the chain as it's drawn through a super long cut. We recommended the .043 chain for the MS192T cause it's a small saw with limited power compared to it's big brothers. But in the 12-16" range on a 30cc saw, a skip tooth chain would be unecessary if were even available.
Here's Stihl's explanation of the different chain types.
http://www.stihlusa.com/chainsaws/identify.html
Found this in an older thread:
Green label chain is “low-kickbackâ€, “homeownerâ€, or “safety chainâ€.
Yellow label chain is often called “aggressive†chain.
Stihl Micro is Semi-Chisel (Rounded Cutters)
Stihl Super is Full-Chisel (Sharp Pointed Cutters)
Stihl Picco is equivilant to “Low-Pro†or Low-Profile chain from other brands.
Common chain pitches: 1/4â€, 3/8 Low-Pro, .325, 3/8â€, .404â€
Chain pitch is the distance between any three consective rivets divided by two.
Chain gauge is the thickness of the drive links and sometimes the tie-straps/cutters.
Chain length is the number of drive links in the chain loop.
Full Skip means the chain has half the usual number of cutters compared to a normal full-comp chain.
Half Skip means the chain has 2/3 the usual number of cutters compared to a normal full-comp chain.
Full Comp means the chain has all of it’s cutters and is what typically is on any given saw that isn’t on a logging truck or in Jay’s shop.
I highly recomend browsing Stihl’s library of chain info and watching their videos for how-to’s on chain ID and sharpening. Lots of great info that applies to far more than just their product. The more you learn about chain the more you’ll like theirs tho so watch out! ;-)
http://stihldealer.net/videolibrary/OnePlayer.aspx?v=22&vt=22&vb=0&id=22 - The chainsaw instructional video.
http://www.stihlusa.com/information/STIHL-Sharp-Advice-Saw-Chain-Guide-Bars.pdf
