M
MasterMech
Guest
Had to tune the MS460 anyways after a carb cleaning. Good opportunity to show how it's done from scratch.
(stock... No thanks)
.What about that DP Muffler??(stock... No thanks)
That looked and sounded good. Great job MM. Loved that rebuild thread. Now run the chit out of that thing
Sounds really healthy ! She's oiling well too .
Why no tach? You can tune by ear only too. Forget I'm using a tach and listen to what's going on.That's greatNow now do one , explain and use no tach ,please
That saw was "pre-warmed".I would have made a cut or two in order to make sure the engine got to full operating temperature prior to making adjustments.However that is my personal preference, Ken
I here yaWhy no tach? You can tune by ear only too. Forget I'm using a tach and listen to what's going on.
The audio breaks up too much for me to really hear whats going on. Can your hear it four-stroking at WOT? It should have a rough tone that will smooth out as soon as you put it in the wood.
, I am just a cowboy with a bag of tools.
Then perhaps there is something to be learned from the professionals.![]()
I supposed there is no reason you couldn't do it sans bar & chain, but adding the B&C would change the load and I would check it by ear at least before trusting it. I haven't done one that way but I would expect it to significantly affect the top end RPM setting.Dumb question but can it be done with the bar and chain off, or does it have to be under load (of a rotating chain)?
What if you have a saw that otherwise runs perfectly but it will die when you let off of the throttle after in a cut. Doesn't die if you are just revving. Also it doesn't die after a cut if you feather the throttle once or twice before letting it idle.
