For those of you who tune and adjust your own chainsaws how close are you setting the high side to max RPM? What I'm finding is that the blubber sound (4 stroke) occurs way below the specified maximum RPM.
For example on my Husqvarna 365 Special (older style with the Zama carb) the maximum RPM specified is 12,500. I could hear an obvious blubber at 10,500 but at the current tune of 11,500 I can no longer hear it. Saw started with one pull (choked, fully cold 42F outside), idles correctly at 2700rpm and accelerates well. Spark plug is brand new, air filter just cleaned, carb just disassembled and cleaned, using ethanol free premium fuel with Stihl Ultra 50:1 mix). Some blue smoke on startup but after warmed up it clears out.
Should I be tuning closer to where I hear just a little blubber (full throttle no load) or closer to the maximum specified RPM. I don't want to leave any power on the table but also don't want to run too lean up top.
