Just got 8 chains sharpen at the dealer (50.00 bucks WoW) so I am in the market for a chain grinder Looking for a good one as I go through some chains in a month time. Any advice?
not afraid to spend the money just drop 50 bucks on 8 chains got another 8-10 chains that need sharpenkevin j said:search, or search on arbositsite.com
general consensus is harbor freight plastic no, $100 Northern Tool china copy quite serviceable, and the oregon or others preferred but much more money.
Ok Ive got 8-28 in. chains how quick can YOU file them? and if your as good with the file as you are the maul should go quick ( iam looking at the new maxx or oregan 511)when i hand file it just seems like a big chore thats never going to get done I usally just buy more chains so i dont have to file! Or thake them to the dealer where they charge me 50 bucksMMaul said:J I bought the harbor freight one a year ago total piece of crap. I like to use the Stihl 3/8 file set. Works well.
I would spend 5 min. but on a 28 in. chain seems to take me about half an hour to get one rightsavageactor7 said:J I use a 7/32 file on a 20" chain...takes less than 5min to sharpen by hand. It's worth the time to have some old timer or tree pro show you how, it's not rocket science.
smokinj said:Just got 8 chains sharpen at the dealer (50.00 bucks WoW) so I am in the market for a chain grinder Looking for a good one as I go through some chains in a month time. Any advice?
kevin j said:grinder won't eliminate hand filing. even with the grinder you will probably still hand file, not? touching up way before it gets really DULL enough to grind it. I only have it ground when rock or steel the chain.
k
kevin j said:personal preferences and style I guess.
I have mostly longish bars for the motor sizes, and am a stickler for absolute sharp.
touch it up every couple tanks, or if it even touches the dirt. I'd be going through half dozen chains per day at that rate.
Ultimately though, it is what works for each of us.
I do like the consistency of angles with the ground chain.
Thats what i got but I have 18-20 cords to get done by the end of Jan. and I also work 60 hrs. a week.Thats why I took them to the dealership 50 bucks later Iam thinking Its time to buy my one!Bigg_Redd said:Here's what sped up my hand filing: I started buying round-bit, skip-tooth chains. Half the teeth to file and the round bits stay sharp longer. But I've only got a couple hundred posts, so what do I know?
Iam looking at the maxx The new Italian-made MAXX grinder allows bi-directional grinding because it's designed with a head that tilts left and right (90 degrees to 50 degrees) and a table that's fully symmetrical. Unlike other grinders, this unique design allows you to get the same results on both left and right hand cutters. The automatic chain clamping mechanism is activated when the head is lowered. Additional features include a built-in light and cast aluminum base, head and table (no structural plastic)It will clamp anywhere from .043 gauge chain to .080 without the 3/4 adapter. And also the 511 ajdemaris said:MMaul said:J I bought the harbor freight one a year ago total piece of crap. I like to use the Stihl 3/8 file set. Works well.
Most of the little grinders are useless. Angles are inaccurate for one. Other big problem is the lack of other adustments that are needed for certain chains.
Most standard round-cutter 3/8" chains get sharpened at a 35 degree angle - with the file at a right angle to the chains - i.e. 90 degrees. Most cheap sharpeners are fixed at that 90 degree angle and cannot be changed.
Many full-chisel chains require that angle to be 80 degrees - sometimes 75 degrees to the bar - along with the chipper angle being 25 or 30 degrees instead of 35. If the sharpener does not have those extra adjustements - it can be pretty useless. There is also a third adjustment needed that only comes with the better machines.
Over the years, I've had access to many, high priced sharpeners since I worked as several places that sold and repaired farm and logging supplies. We has Bell Saw, Peerless, Stihl, Oregon, etc.
The best sharpener I've used - for a fairly low price is the Oregon # 511A. Northern Tools and Harbor Freight both sell it at times. I bought mine for $159, on-sale, a few years ago. I see now it's over $300.
whos CLWet1 said:I always hand filed with much success, but I also got bogged down with the time I was spending on them so I ended up buying a grinder (well actually two grinders).
I picked up the NH grinder first and found it to be a decent machine for the money. I bought mine on sale ($85) and can't say there's much wrong with it. In fact, it appears to be an okay copy of the Oregon grinder. I would doubt you'll find a better chain grinder on the market for the money as it has everything you need to get the job done.
I also bought a used Silvey grinder for doing square grinding. Now that I've been spoiled with the square ground chain, I have little use (or desire) to ever use round ground chain again... what a difference! I'm holding on to the NH round grinder for taking down the rakers and using it with my small chains, but I don't plan on using round ground on 3/8" chain again if I can help it.
BTW, I think I paid $300 for the used Silvey grinder, which also included a new 32" bar, three new matching loops of square ground chain, and a hand full of new wedges... quite a bargain! If you're in no rush, watch CL for high end used grinders, they do pop up from time to time.
got it been wachting thereWet1 said:
