Ceramic Blanket Or Roxul on a top of the Block Off plate
Dmitry
1,200
CT
Does it make sense to put /glue ceramic blanket on a top of block off plate of Roxul that was cut to fit would be enough?
Thank you.
No.
And "a top off plate of roxul" is not right. It should be sheet metal for air sealing, and roxul on top of the sheet metal for insulation. Roxul itself is not a block off plate.
No.
And "a top off plate of roxul" is not right. It should be sheet metal for air sealing, and roxul on top of the sheet metal for insulation. Roxul itself is not a block off t
No.
Sorry, it was a typo, I meant “ or”, ill edit
Thank you.
Sorry, i meant "or peace of Roxul that cut to fit" Can't figure out how to edit.
No problem..
Yes, do put something non-combustible with decent r value on top of the plate.
Roxul has more r-value, is easier to work with, and is cheaper.
