- Sep 30, 2007
- 58
central boiler has green poly pex pipe with a thick wall that they used to run in my basement. i need to make up a by pass line with pex and i cant find that heavy wall green pipe just regular pex . will that regular pex be fine? also giving those shark-bite fittings a try..
what i planing on doing is just kill the power to the water circulating pump in the morning before i go to work and by the time i get home it should be cool enough to cut the pipe and work with it.
any other suggestions or pointers are welcome.
thanks ant.
thanks ant.
