central boiler and fire brick
adamant
58
i am able to get some 2'' thick fire brick. do you feel that i would benefit by installing it on the floor of the burner?
My thought is that firebrick is pretty cheap, and if there was a way to improve the performance of a CB by installing conventional firebrick, they'd do it at the factory. But people who know a lot more about these things (mikey, for example) have given it serious consideration, so I'm curious.
Good point, Eric, thanks for the compliment, but I'm just a dumb 'ole country boy, but...adding firebrick adds to mfg. and shipping costs...my dealer recommended to let the ash build somewhat to protect the metal. Only thing I'm concerned about is busting up the brick when I throw big chunks of wood in.
IME, with firebrick-bottomed stoves, gravity and compacted ash combine to keep everything in place. Of course, the bricks are going to crack over time, but if they're packed tight on a flat surface, they'll stay put.
I read an article on woodheat.org (I think it was there..) where a guy did this... It almost doubled the efficiency of his OWB........... Only he lined the bottom, sides, back, door, and top (ceramic board) when he did it........
I will be installing a CB 6048 very soon and had the same idea. I called Cental Boiler and they said I would void my warentee if I placed the firebrick in the stove. Maybe you could check this out and see if you get a different answer.
another reason to consider doing it would be the heat retention from the firebrick....what was CB's reasoning for saying it would void the warranty?...too much weight from the brick?
Said it might collect moisture under the bricks when not in use. I had the same idea as you. Maybe you could check and see what they say.
The moisture problem could be a real one indeed..... For me, I'll be running my system once it's up 24/7/365 for DHW......... (Not the burner, just the system with it's 1250 gallons of storage)....... so that would be a moot topic.....
I think you should be fine if the burner is used at least weekly year round.. But I don't take any responsibility for what happens! :)
Incidentally, aren't their stoves supposed to be the "miracle" stainless steel? What damage would moisture do if they were really stainLESS steel??
