I'm actually likely going to be on top of ledge, trying to find a flat enough area to putAssuming you are asking about an outdoor boiler, it really depends on the underlying soils. If you are on well drained gravel, pouring a pad is usually not an issue but if you are on clay soils that can heave a potentially warm pad surrounded by frozen soil can be a big issue as in the spring things can sink and heave. I would recommend at minimum, strip out the topsoil, put down some geotextile and a layer of 6" of crushed rock under the new pad. The geotextile keeps the underlying soil from working into the crushed rock and the crushed rock keeps the area drained and can compensate for frost issues. Pay extra for steel mesh in the pad and add polypro fibers in with the concrete. If you are pouring a pad make it bigger than you think you want. I would pour a big apron out front as its going to get muddy throwing wood into the boiler in spring conditions.
Yea, i did actually google the weight limit of cinder blocks (1700 PSI) and the weight of the G4000 + water should be about 2400 pounds, which will equate to 600ish pounds per leg.If you are on ledge then some gravel and blocks would probably work...just make sure the feet are sitting right on the web (center) of the block...there is some real weight there when full of water n wood...
Yeah the block will support it for sure...but I personally still wouldn't want a boiler leg sitting right on the hollow core part of the block, they are not meant to take a load like that...meant to take load vertically, but you wouldn't want to use the block like that, in its "normal" position, since it would more easily sink into the ground/gravel over time...but I guess I'm making the assumption you were planning on laying the block on its side for this...Yea, i did actually google the weight limit of cinder blocks (1700 PSI) and the weight of the G4000 + water should be about 2400 pounds, which will equate to 600ish pounds per leg.
Or an even better option, a cement pad. A pad 8' long gets you out of the mud during the shoulder seasons when the ground isn't frozen. You can kill two birds with one stone.Just use solid block then
Or even better put your stove inside. LolOr an even better option, a cement pad. A pad 8' long gets you out of the mud during the shoulder seasons when the ground isn't frozen. You can kill two birds with one stone.
A G4000 is UL rated to be installed indoors. Mine will be going into a barn next year.Except that you are heating the outdoors with the boiler, its not a bad idea to feed it through a hole in the wall but not sure if fire code allows it.
Out of curiosity, how do you plan on putting your electric and lines in if you are on top of ledge. Can you dig through it with a backhoe ?I'm actually likely going to be on top of ledge, trying to find a flat enough area to put
You can also just buy solid block already madeAs a point of interest and you can use this for other applications. I noticed a recommendation of using block and that it might be weak at the center hollow two sections. What I did with an 8"X8"16" blocks (to add weight) in my creek bed to prevent soil erosion was to fill the two holes with "Quickcrete" from Home Depot. My only purpose was to add weight so that I don't have the blocks washed downstream during a heavy rainstorm. Here's the specs:
Block Empty = 32.5 lbs
Block Filled with concrete =65 lbs.
John M
P.S. I am confident with the concrete filled blocks, there won't be any issue of them breaking/cracking
Or as @sloeffle mentioned, just pour a pad...which I think I'd lean toward, even on ledge...probably pretty hard to get a nice level spot made for the OWB to sit on when dealing with ledge anyways...and those OWBs want a level pad to sit on...often have to shim the feet to get them all 4 sitting flat, even on concrete.You can also just buy solid block already made
Oh I don't disagree at allOr as @sloeffle mentioned, just pour a pad...which I think I'd lean toward, even on ledge...probably pretty hard to get a nice level spot made for the OWB to sit on when dealing with ledge anyways...and those OWBs want a level pad to sit on...often have to shim the feet to get them all 4 sitting flat, even on concrete.
