Cautionary Tale
bogieb
3,585
South Central NH
Took the Harman down this morning for a good cleaning, then started setting up a St, Croix Harding that I had picked up last night (used) to replace an Englander (got it used, went kaput on the 3rd firing, sold it) and it took some finagling of the pipe as the SC exhaust is just slightly lower than the Englander was. Then went into town and got gasket glue as the gasket, although fairly new, had started coming out (during the road trip last night, apparently the door opened and gave the gasket a good wind test). Glued in the gasket and had to wait at least an hour before trying it out.
So, about 2.5 hours ago I decided it was time to try it out. Started up, then gave me a code. I checked the door, and it wasn't closed all the way, so closed it and pressed Start again, and away it went. I was checking the connection in back for leaks, when I turned around and smoke was pouring out the door. I shut it down right quick. Then started opening doors and windows (20 degrees out then) to let the smoke out. Hell, I don't think there was any fire even, it was in the space of 2-3 minutes from when I hit start.
After thinking about it while setting up fans to evacuate smoke, I decided to check the pipe to see if anything was plugging it up. Duh, I had put balled up paper in the pipe, to keep the cold air out when I removed the old stove, and evidently failed to remove it all. However, since there was no heat, removing the paper in no way helped with the smoke removal. After about 30 minutes of smoke pouring out the door, I realized that I should shut the damper as it was getting air in thru the OAK. about an hour ago the smoke finally stopped wafting out. Now I am unsure if the gasket is good or not. I expected some smoke, but it was roiling out of there. I'll probably just replace the whole dang thing to make myself feel better.
I have stoked up the basement Harman to High/Manual and started up the propane heater to get it to a reasonable temp inside (since shut down as it is 64 in the house now.
I am such a knucklehead sometimes, but will use this to make the point that if double and triple check if you have plugged up old pipe, then set it up again! and yes, I have smoke and CO detectors (and a bird as an early warning system - LOL).
How many of you who looked at this, and didn't comment, said to yourself "What an idiot."? I freely admit that I was stupid, just wanted to put it out there for other newbies to see. And for those of you who looked and didn't comment, thanks for not rubbing it in.
RUB, RUB, ......RUB! Cough,, cough! ;)
Reactions: bogieb
Plug your vent over the summer or you may have same problem again next year in the form of a bird or bug nest.
Reactions: bogieb
I'll find some one to Rub It In but they will want to use scented oil ! :cool:
Snort, gag, cough. Did the smoke detectors work? Just bought a new photo electric one to tie into the system. Need to replace all in home as their getting close to ten years old.
Everybody has a bad day now and then ... looks like you saved up a bunch of them for all at one time. Taped reminder notes are a wonderful thing!
Reactions: mustangwagz
As long as you can laugh at yourself you're good to go! Get up, dust your ass off, and drive on! She was having an emergency response practice drill.:ZZZ Has everyone else gotten theirs checked off of the safety list?;) Today it will be up and running with all of the glitches worked out.
Oh yea, Pics or it didn't happen.
Reactions: bogieb
So, is it working OK now ??????????
After opening doors/window went and disconnected all the smoke detectors so I wouldn't have to listen to their cacophony!
I'm going to replace the door gasket before trying again. I wasn't happy with the seeming looseness of the door to begin with, so want to make sure I'm more sure of it before trying again. Hope the local hardware store has the appropriately sized gasket. Otherwise will have to order one which means I would have to wait until next weekend.
Looks like I should have thought more about using those words - just surprised more haven't gone in that direction :)
Hey, I kept it clean! I was rubbing it in and coughing about the smoke and rubbing it in.:p The thread is still young - give them some time. Today is your day of vindication. After all, you didn't say rub it out.:) That would have raised some brows.
Dang - the gasket is 7/8", which seems to be a strange size so hardware stores don't carry it. Ordered one online, but will have to wait for it to get here. And naturally, any St. Croix dealers (who may or may not have it) are closed today. And measured the one the previous owners had put in as a replacement, and it isn't the right size so don't want to try it again. AAARRRGGGHHH!
I have to give you kudos for keeping it clean, and funny. And yeah, Those alternate words would have invited everyone to chime in!
Reactions: Gabor129 and bags
I have not done that YET!
Hopefully, I learn from other peoples tragedy...I may search for this thread next fall and thank you by adding my own stupid story to it.
Bill
Bill
Not quite a tragedy on my end, just unpleasant after-effects.
I look forward to seeing other peoples mishaps - as long as they didn't involve destruction or bodily harm that it.
