I though this may help someone else. When I installed my pellet stove it said in the directions to silicone the pipe joints. I did this but now I can not get them apart to clean. My stove is in my finished basement family room and it top vents through stainless steel 6" single wall pipe into a masonary chimney and is reduced to 4" stainless steel pipe up 18' to a cap. When I installed I put a 12" stainless steel draw band on thinking I could remove the 2 bolts and put my vac into the 6" pipe back into the 4" 90 elbow at the vase of the chimney. But when I removed the bolts on the draw band the silicone is holding too tight that I could not get it loose. I put the silicone on the 2 pieces of pipe and slide them together and then installed 3 screws. I shoud have put the pipes together and then put a small bead of silicone on the joint. I think that I will try to use a heat gun on the draw band this week and see if I can get the silicone hot enough to get apart. I was just trying to do a good safe job, I guess I did a little over-kill !
Happy Burning
Pat
Happy Burning
Pat
