Caulking bricks outside fireplace
savathearth
2
CA
Hello,
I'm new to DIYs and would appreciate help on this.
1. I have these red bricks outside of fireplace. What kind of caulking should I use to fill the gaps between the red bricks outside of fireplace?
2. What kind of mortar should be used inside the fireplace to fix the cracks and gaps?
I know this would be personal preference but would you consider leaving the red bricks as-is (just clean them) or paint them white?
Thanks.
  • Caulking bricks outside fireplace
Hello,
Thanks.
You mean between the brick and trim? Just painters caulk will work.
In the firebox refractory mortar
Don't paint it if you want to use it
I think you will not find any paint that will hold up inside the fireplace.
One of my SILs who does faux, murals and straight painting, painted the brick above the mantel and accented the brick around the fireplace to lighten it a bit.
Reactions: kennyp2339
