I want to understand this and found what is probably my answer but it's too vague for my understanding.
I allow my GreenMountain60 to burn out every night with the bypass closed and want to either
1) Make sure doing this isn't shortening the life of my catalyst and therefore the bypass should be opened at night, or,
2) Since colder gasses are okay at the end of the burn than in the morning when I start my fire it's okay to close the bypass early so long as I have a good fire going.
This question was asked in 2018 here - https://www.hearth.com/talk/threads/prolonging-catalyst-lifespan.170785/post-2292342
Although the question is more about possible heat shock to a cold catalyst. BKVP posted with some knowledge about moisture and says to look at burn charts, but I can't find the burn charts he's referring to. I imagine his statement "first stage of combustion...boiling water out of fuel..no measurable moisture at end of burn." is the answer, but wanted to follow up about this burn chart. He mentions "We need "catalyst conversion" to begin before we shove 100% of gases thru the combustor"-- to clarify he means "closing the bypass", correct? I don't know if he actually means there is a way to shove less than 100% of gases using a particular stove. (yeah, I'm probably reading into this)
